s7 to hmi problem
darren221170
Feb 2008
leeds
18
Hello all, I had a sf fault on a s7 plc. I turned off the plc pulled out the mcc card and did a reset. I then put the mcc card back and reloaded it to plc.Now i have no communication with the hmi.please help!
sounds like your network settings are not there since you reset the plc..netpro etc
Does your io work? this is the hardware config
do you have the original project and siemens plc programmer etc, if you do u could reload it or recreate it if needed
Has this cured your sf fault ?
Yes i can see all the blocks on the plc,i can even see the hmi on the network and yes resetting it cured the original sf fault. It's a micro innovations hmi i think maybe the problem is with this?
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
888
Hi guys I have a system of mp277 key hmi, s7-300 plc Hmi has damage, so I bought weintek hmi to replace it I have the cpu program so I got the...
1,094
Hello I hope someone could help. I have installed Intouch 2014 R2 on a new HMI, Loaded the Intouch Project, Load DB, Configure the DAServer...
1,472
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,297
I have a Omron CP1L PLC that I'm having problems communicating with a NS5-SQ11B-V2 Omron HMI through ethernet . I have the exact same set up on...
2,096
