S71200 Tcp Communication.
Nelliyan
Sep 2011
90
Hi to all,
I am using s71200 plc...
I am sending some spec values from my plc to the module1 continuously through TCP communication.... Now in that same program i have to send a frame to a module2(both module1&2 are third party devices) which has to be send continuously without disconnecting the transmission..
Now the issue i am facing is, i was able to communicate with either one of the module , to communicate with other i have to disconnect one communication..
But my application is to send data concurrently to both the module1 and module2 which are having different ip add & port address... First of all without disconnecting the communication, the data transmission between 2 slaves and one master concurrently is possible or not????
Pls guide me
Regards,
Nelliyan
The issue is how many "sockets" the CPU1200 can open concurrently.
"S7-1200 System Manual" does not explicitly say anything about the number of concurrent sockets. However, from the way TCON/TDISCON, TSEND/TRCV are used, I think the system can handle only one socket at a time.
Are you polling two Modbus/TCP slaves?
Rahul
http://www.voltsmith.com
i am using 2 tcp slaves
I cant use modbus because one of the module does not support... module one is micro controller based device....
Can u tell me how to disconnect a communication socket using the T discon... I tried to check it manualy but no response in the DONE, ERROR, Busy status of that disconnect block...
Dear Experts, Warm Greetings ! By using TCON,TSEND,TRCV,TDISCON block,I am trying to make communication with my...
1,497
Hello; i'm having some troubles with a com test i'm handling. i have another end for it, but for now i would like to have : M241 in io_scanning...
3,502
Hi Folks. Has anyone used an SEW EI7C encoder with an S71200 PLC? If yes, how is it done? I use this same encoder in EI76 mode with a...
269
Hi everyone I am completely new to using shift registers and am a bit stuck, my shift register works as should, it is for an overhead conveyor...
55
15,702
I got Meinberg as NTP server, and it is in same network as My S71200 PLC. I went (Device configuration -> Ethernet Port ->time synchronization)...
2,716
