Safety relays for pressure transmitters
paulB
Apr 2003
171
This is not exactly PLC question.
I have application, where SIL 2 pressure sensors need to be used. I was not able to find any SIL 2 pressure switches suitable for required process environment, 150psi, 350 degree F. I was able to find pressure transmitters (Endress +Hauser), which are SIL 2 rated and suitable for required process environment. Are there safety relay exist that will accept 4-20mA signal? I do not want to introduce "safety plc" with "safety rated" analog inputs. Functionally, application is simple, door is locked, and door key is trapped. Trapp key device is safety rated. When pressure drops to 0 psi, key can be un-trapped.
If anyone heard of such thing, please let me know.
Thank you,
PaulB.
Thank you all for the links.
STA and Pepperl+Fuchs should work with analog inputs.
UE switches might have models suitable for required process environment.
PaulB.
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS...
149
Hi all, has anyone ever had any issues with premature failure, etc. when using contactor relays on pulse monitored safety outputs? We are...
776
I have panel which controls a batch pasteurizer. The panel has an E-Stop and a safety relay (Schneider XPSAC5121) which cuts power from all DOs of...
4,614
Hello everyone, I have some problems with safety relays and AS-i. I need to draw project for my final exam, but I don't know how to use/wire them...
1,636
At what point does one jump ship from the standard Guardmaster safety relays within a panel to a Compact Guardlogix or other safety PLC? Im sure...
3,449
