Red Lion Crimson 3 software has 'Internal' Tags that can be configured to be Retentive.
If you move a value from a PLC-connected Tag or another internal Tag into a tag that's set to be Retentive, it will keep that value through a power cycle.
You can use an ordinary Button with a Change Value action to set that tag, or use an assignment operator inside a program or Action (like "Saved_Value := Current_Value").
Crimson also supports Array Tags, so you can store multiple values and index through them relatively easily.
You can also read and write basic file I/O if you want to store those "recipes" as TXT or CSV files on the CompactFlash card of the G306.
