Scaling Allen Bradley
sharmn1
Dec 2010
Durban
Hi am using a scaling block for a analog input 4-20ma seem pretty straight forward, but the problem i have is in block settings the input is not being read therefore i cannot see a scaled output.
Have i forgot to put a a simple setting.
Alan is your crystal ball working - mine is not
More info please Sharmn1
Is your subroutine being executed?
Is the input wired correctly?
If you can zip your program and attach it to a post that could help.
467
I have 1769-IF4 module and 1766 micrologix 1400 series B controller, when connecting Analogue input in module it's showing maximum values of...
1,741
Hi All, I have this simple question. Please don't judge. How can I scale an AI from Analog module raw value to engineering value? I've searched...
17
6,939
Hello everyone PLC -1769-L33ERM Analog Card - 1769-IF4 Input Range - 0V to 5V Data Format - Engineering units Scaling required - 0 to 1000 So...
3,432
If using a ab analog module do you set it up to use the raw value or do you set it up to scaling for PID? I have always used the raw value. Not...
2,616
