Schneider Altivar 32 vs 312
CapinWinky
Aug 2011
Virginia
566
I'm doing a new Elau/PacDrive3 system and I'm trying to decide which VFD to use. The issue is, the 312 is $150 cheaper per drive, but doesn't have STO, so I have to kill power to the drive and have the redundant safety contractor to do that. In addition, the 312 would be a different protocol while the 32 can be on Sercos with everything else.
At 5 axes, it's in a weird grey area where the 312 and contactors are noticeably cheaper and the sizes end up needing the same panel size to fit, but it's a low volume machine and the 32 and STO are just nicer. I just don't know if they're $100/ axis nicer.
Anyone have an opinion?
Never mind, power cycle frequency limit on the 312 input is 1 minute which is too long for our E-Stop recovery. Doing a safe disconnect on the load side of each drive both eats up the price difference and I'm not sure if it's even allowed.
Hi Can anyone help please ?? I have a Schneider Altivar 71 that I am replacing with a different drive. It has two terminals bridged LI1 and LI2...
988
Is anybody using these drives and collecting DATA from them? I have a lot of these drives out in the field, all hooked to our SCADA gathering the...
1,642
Hello all, I have a problem to set up correct configuration with Schneider Altivar 340 in RSNetWorks for DeviceNet, CPU is CompactLogix L33ER...
1,904
Hi all, I am trying to control and/or read values from Schneider Altivar12 VFDs. Via Modbus on a AB Micro850 PLC (using the Connected Components...
4,039
G'day Everyone, Been having some trouble lately with some of our Schneider Altivar 61 VSDs. These drives run along nicely but sometimes when we...
2,471
