Schneider Altivar VSD
pbaker88
Jul 2013
Victoria
22
G'day Everyone,
Been having some trouble lately with some of our Schneider Altivar 61 VSDs. These drives run along nicely but sometimes when we get a powerflick the drive stops running and and it needs to loose its run signal to be able to restart. No faults come-up on its screen it says its ready to go. They are controlled over omron devicenet but ive also had a few cases where they were wired from the terminals and its happened. Has anyone else had this problem as i cant seem to see any parameters point me in the right direction.
I've seen it on multiple designs... If the power loss is not long enough for a good fault, the auto-reset doesn't fire, and the drive is left in an alarm or worse.
Quite a few drives require a toggle of the run input to restart. Some have it as an option, to satisfy safety in a plant, but are a PITA in an un-manned, remote application.
One possibility, that works most of the time is to wire a n/o 'healthy' (powered up and no fault) contact in series with the run input.
Hi Can anyone help please ?? I have a Schneider Altivar 71 that I am replacing with a different drive. It has two terminals bridged LI1 and LI2...
988
Is anybody using these drives and collecting DATA from them? I have a lot of these drives out in the field, all hooked to our SCADA gathering the...
1,643
Hello all, I have a problem to set up correct configuration with Schneider Altivar 340 in RSNetWorks for DeviceNet, CPU is CompactLogix L33ER...
1,904
Hi all, I am trying to control and/or read values from Schneider Altivar12 VFDs. Via Modbus on a AB Micro850 PLC (using the Connected Components...
4,041
I'm doing a new Elau/PacDrive3 system and I'm trying to decide which VFD to use. The issue is, the 312 is $150 cheaper per drive, but doesn't have...
2,073
