Search and compare with PV PLus6 & ML1400
Beanie
Nov 2003
Hello All,
This is probably simple for most but I'm banging my head against the wall. I'm trying to limit access to functions with a password. I'm using a PanelView Plus 6, I'm loading up tags(Stings) from a CSV file on SDcard. Operator enters a password, I want to search against the tags and grant access or not. Seems so simple. I have a fixed number of tags(250), but not all will be populated that will be up to the customer to maintain the CSV file. I am connected to a Micrologix 1400. But I'd rather do the Search/Compare in the Panelview if possible, if not I can push all the tags to the PLC, which I have done and did a 250 line of ladder with simple compare rungs but that seems so primitive. I need to do this with 4 more questions, seems like i may run out of memory or bog the system down if I have to compare 250 lines of code with each question.
Any thoughts or point me in a different direction??
Much appreciated.
Jim
I have done this with a CompactLogix L18 Controller and a PV 600. I used the File Search and Compare (FSC) instruction. I am pretty sure that the SLC/Micrologix do not have the FSC instruction available. So the "Brute Force" method may be the only way to make a Micrologix work.
Any chance you change to a CompactLogix PLC for this? With the ability to do arrays and use the FSC instruction to search those arrays you may be money ahead in programming time and performance.
Just a thought.
Hello Everyone, I am searching doing a search using my compact logix L33 and I want to show all the data found ( it can be as high as 60, 70...
3,026
With the FCS instruction in a PLC 2 would this be the same as using a SQC in a SLC? Does the FCS do the comparison as long as the rung stays true...
4,003
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
259
I have an InTouch HMI that has PID parameters. I need to find what the PID values were in the past. I have backups from the past, but none...
48
5,601
Good morning folks, I'm on a quest to find all of the references to the CurrentUserHasCode function in our project. I have the project...
443
