Search GSD file to configure the Profibus network
kyuclangtu_bk
Dec 2009
Ha Noi
I have a block valve FESTO, with code like this:
1. VIGA 03-FB-4 (18,656 L307) - 4 Digital Output
2. VIGA 03-FB-4 (18,656 L307) - 4 Digital Output
3. VIGE 03-FB-8 (18,655 L307) - 8 Digital Input
4. FB9-03 (18739 L307) - Profibus station
5. VIGM-03-4, 0 (18,652 L302) - 2 valve
6. VIGM-03-4, 0 (18,652 L302) - 2 valve
7. VIGM-03-4, 0 (18,652 L302) - 2 valve
8. VIGM-03-4, 0 (18,652 L302) - 2 valve
9. VIGM-03-4, 0 (18,652 L302) - 2 valve
10. VIGM-03-4, 0 (18,652 L302) - 2 valve
11. VIGM-03-4, 0 (18,652 L302) - 2 valve
12. VIGM-03-4, 0 (18,652 L302) - 2 valve
The sorted order from left to right.
I configured the Profibus network to block FESTO valve but no corresponding GSD file, you do have this GSD file please help me! Thank you very much!!
Dear All
I tried FB9-03 GSD file, however, it does not have the corresponding module such as module-type VIGM 03-4, or module 4DO Category: VIGA 03-FB-4. So, when I configure the Profibus network, the network fails. I tried many times, enough as a module in the GSD file FB9-03 but the results still failed. Please help me!
The system that I configured for the Profibus network block valve FESTO above, it is the system previously used Simatic S5, I upgraded the system to the Simatic S7. The configuration file for the FESTO valve S5 do not have!! Indeed is difficult!
Oh, truth is too hard!
truth is too hard, do not speak truth is too hard!
Hi Could really do with some help, please. I'm trying to find HMS_1011.gsd for an AnyBus communicator OPC-G11S-PDP. I've tried their website...
3,056
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
255
I have an InTouch HMI that has PID parameters. I need to find what the PID values were in the past. I have backups from the past, but none...
48
5,560
Good morning folks, I'm on a quest to find all of the references to the CurrentUserHasCode function in our project. I have the project...
432
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,023
