searching HMI(+plc) of any brand
MBS
Apr 2011
Bavaria
Hi everybody!
I am in search of an HMI of any brand. The requirements are:
1) The product must be able to send ASCII commands via the serial RS232-interface to a connected camera by pressing a button at the touchscreen of the HMI (necessary requirement)
2) The screen of the HMI must be programmable, so that I can decide which/how many buttons to implement (necessary requirement)
3) It must be a relative cheap solution because I need the HMI only for sending ASCII-commands: maximum ca.650€/950$ list price (necessary requirement)
4) It would be useful if the device had two serial outputs (optional requirement)
5) Technical service for the product should not be bad (optional requirement)
Can you recommend a product to me which meets these demands?
Thank you for your efforts in advance!
MBS
Hi everybody!
MBS
Take a look at Horner.
Pretty much everything you asked for is included.
Not sure what the European site is but here's the US link:
http://www.heapg.com/
Hope this helps.
Quick reminder:
If you don't need build-in I/O they sell units without.
You pay less for it but still get all of the above.
If you check out the Red Lion units, look at their Kadet series also. These are lower-cost units but will do everything you specified including dual serial ports with ASCII capability.
I'm testing the crimson-software for the G306K these days. But I've got two questions about the crimson 3:
1) Are the ASCII-commands (e.g. "lih on") put in the first field of the data source of a string-tag while the source is configured as "general"?
2) Do I have to set a communication port (the RS232-interface) for the mentioned string-tag or how does the string-tag "know" which port and therefor protocol he should use for communication with the camera?
Good morning, I'm searching for a power supply to convert 3 phase 480VAC to 120VAC and 24vdc. Is there an all-in-one power supply like this on the...
115
is it just me, or has something happened with the google search when using chrome? looks likes safari on mac is ok, but edge/chrome on windoze has...
870
Besides using BootP in the past, I am relatively new to having to look for privately addressed devices in many control networks. All of the...
23
4,103
Good morning, could anyone recommend a 24VDC pulse counter which counts up or down to a preset #? Once it reaches this number, send a 24VDC back...
1,671
Hi, Using FactoryTalk View SE version 9.0. Wondering if someone can help me as to whether or not I can search an entire display for instances of a...
2,328
