turbohamad
Dear Members;
We are going to design a Simplex Control System With Following:
1. 24 Digital Inputs (SIL 2)
2. 24 Digital Outputs (SIL 2)
3. 4 Analog Inputs. (SIL 2)
4. HMI 15" Touch screen. (IP 65)
5. PLC controller with following specification:
COMMUNICATION INTERFACE Industrial Ethernet, 2x RS232 / 485
DEGREE OF PROTECTION IP 20
MEMORY SIZE At Least 2048 KB
CONTROLLER PROCESSING TIME 0.00005 ms
SUPPLY VOLTAGE 20.4 V DC TO 28.8 V DC
AMBIENT AIR TEMPERATURE Operation: -10º to 50º C
MEMORY TYPE USER DATA Minimum 1024 KB RAM
The system is simplex no need of function blocks. Its just control the process by Bits on and Off, Analog inputs is used for pressure transmitters which control the bits by reading the desired mA.
Please guide me what i choose Siemens, Rockwell, Omron, Mitsubishi or ABB.
Which software are use for programming the PLC and Design the HMI (Included Graphical presentation) as per your suggestion.
Regards
Regards
