Hi all,
I m trying to read several registers using serial line(rs485) in m251 plc. I want to know the limitations, as I m facing serious issues of inconsistency. I m using Read_Vars for this, and i m using around 11 of those. Apparently not more than 8 can be active at once, so i have sequenced them, but still i often get error message of 255 (communication error) and 1 (oper error). The registers i m using are not in sequence, so I can’t just use one Read Var block, and the huge number of read vars I believe is causing inconsistencies.
Any suggestions? Any similar experiences ? Any solution?
