Incorrect serial communication
Acmesereno
Aug 2021
South Carolina
I have a zebra barcode scanner connected to a ******* device master UP. They are connected by RS232. By checking the serial logs on the device master, I see a few characters of the barcode come through but not all of it. The number of characters recieved is random but generally 2-4. There are no frame errors in the communication statistics.
What trouble shooting should I perform to find out why this is happening?
Zebra DS3678-ER
******* DeviceMaster UP 1-port
It sounds like the device master is timing out before receiving a full complement of characters from the barcode scanner. Check the settings and look for a 'timeout' parameter and increase it. Better yet look for a 'delimiter' parameter and set that to match what the barcode scanner sends to indicate the end of the barcode, typically a CR/LF, ASCII 13 followed by ASCII 10.
It could also be that the device master's character buffer isn't large enough to hold the entire barcode, but 4 characters would be an awfully small buffer. But maybe, instead of holding the last x characters, the buffer empties when it's full and you're only getting the characters received after flushing the buffer.
try this:
Good day. I encountered a problem when calibrating a channel on the IF16H module. The module is located in the local backplane along with the...
752
I have some programs that i received from 1 of our programmers whos installing a new machine in our plant. He added them to a external hard drive...
1,377
Hi, At the moment, If the user fails to provide a valid username/password, the image attached appears "Invalid password or user name. Logon has...
1,582
Hi all, I am currently having an issue with 3 HMI panel view panels with the alarm list showing the incorrect date and time. It shows up as the...
2,282
Has anyone experienced the following issue on RSLogix5000 (currently on V16) I have a PLC program that has been running on a site for a number...
1,610
