Serial printer
Gabriel577
Apr 2003
Ontario
I'm looking for a way to print data to a printer from a SLC5/04. I have a PanelView 550 connected to the slc via ProfiBus, which has an available serial port, or i can use the slc serial port. Does anyone have suggestions of a setup that works? Any perticular printer?
You can use the AWA- ASCII Write Append comand and related to use the serial port. You can find them in the command reference in RSLogix. You can send any strings you want out the SLC serial port.
You can also use the printer port on the Panelview. It depends where the data you want to print originates.
I don't have much time right now to go deeper, but if you look at the help files for both RSLogix and Panelbuilder, there are explanation of how to do it.
Any serial printer should work. You just need to set the baud, parity and stop bits the same on both systems.
To use the panelview you would most likely want to investigate the "Print Only" objects. They work like multi-state indicators that get sent out the serial port. Note, you can use this also to send data out to another computer, it's not just for printers!
To stuff information into the print only messages, use embedded variables (check the help).
For my money, this would be the way I would look at first.
I have a new L306 CompactLogix running V33 with a 5069-Serial module in order to send data through RS-232 to a Sato S84EX printer. I'm unable to...
1,340
I am trying to print from a Compact Logix PLC to a serial printer (a point of sale type printer - you send it ascii characters to print). Is...
2,335
I need to print data produced by the program PLC (Beckhoff PLC) from a Citizen PMU 2300 printer. More precisely I need to send the data to the...
4,012
hello can anyone share with me the diagram of working cable to make the comunication beetwen plc micrologix 1400 and zebra printer trough rs232 or...
6,338
hi! i am doing a project where . i have HMI with serial printer port. now manufacture cliam that any serial printer will work with HMI. now on...
2,348
