Serial to Fiber Converters
Engineer_UA
Oct 2016
California
43
Hello,
Is it common and good practice to utilize serial-to-fiber converters when interfacing with a legacy equipment that's only equipped with serial ports? Say, if we need to have two devices communicating with each other. Now, if there were multiple RTU's or PLCs, I think it would be better to use a network switch and converters as required to set up the network topology.
Am I on the right track here?
Thanks,
EE
Depends on what devices, interfaces, and protocol you are trying to convert. It is common to convert a serial connection such as DH485, DH+, MPI, Devicenet, etc to ethernet using a gateway for connectivity to a programming PC, HMI, SCADA, etc.
Converters in general provide little to no diagnostic data about their connections. Serial converters are usually pretty good about diagnostics information for the serial port. I'd just ensure the converter provides some information about its fiber connection, specifically power level and error counts.
There are also advantages when the signaling line unavoidably passes through electrically noisy areas or if the end points are at widely different ground potentials.
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
134
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
317
I have lm9030 program on my toughbook CF-29 cannot get my program to hook up with the serial port.
69
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
123
Hello all, I am a college student currently working on my senior year engineering capstone project. As part of this project, I have been given an...
246
