Automation_Tech
Hello All:
I have a slitter/cutter machine that’s just a feed, stop, cut, feed, stop, cut, easy enough.
It works good but, the electronics are old and are in dire need of replacement, its controlled by a micro computer that’s proprietary (locked) and a Movidyn SEW euro drive. With a special position card.
I am going to replace it, with a Compactlogix, PanelView+ and servo drive, the drive is a AB Sercos Ultra 3000 P/N 2098-DSD-HV100-SE
Now to my question, are all servo motors the same? the motor is also a SEW Eurodrive
Name plate:
400V
225hz
4500 rpm
3~
12.0nm / S1Nm
Imax 34.80
My AB guy is suggesting replacing the motor, but I am concerned with the mechanical portion, I don’t think this AB motor will hook up to my gearbox/speed reducer so this would blow my budget if I have to replace the motor. This has a resolver for position and a brake, I will handle the brake in the program.
What do I need to be concerned with?
Many thanks
Name plate:
400V
225hz
4500 rpm
3~
12.0nm / S1Nm
Imax 34.80
Many thanks
