Thanks for the feedback guys
The total cycle time is 12sec, this is with 5 feeds, 4 cuts the sizes range from 12" to 24" on the feed, with a tolerance of +/- 0.015 of a inch, this would include a trim cut, front and back
I was asked to use AB
Thats the positioning card, it needs to go, one of the issues with the older stuff its no longer supported.
I thought of that, but most of the people involved are asking for a PLC controled, so they can service it themselves, we did one with a Baldor (smartmove), but none of the tech could work on it, its getting back into the samething that were in now.
I guess I will look into modifying the speed reducer to fit the AB motor.
The brake on the system now only comes on, well after the autocycle has completed its last motion of the autocycle(aprox 3sec). I have removed the coil on one before and it work fine so I'm not sure of the reasoning for the brake, but it works fine without.
I will be doing this on 12 machines in the US, It would probably be the best keeping them all the same, from the motor back, since the majority of the motors are not the same and it would be a lot of leg work researching the compatibility
thanks again
