Servo Motion Reconfiguration
amir-a
Jan 2012
Melbourne
G'day All,
The problem I am having is that I can not define new points for a servo to follow. I need to add that the software I am working with is Mitsubishi GX Developer. I have been trying to set new route points using data registers which "I think" controls the servo motion. The reason is that the program checks for a specific data register (D4824) to determine the servo position (rung 130)
However rung 107 shows that:
D4824 = D4820 + D4822
D4822 = 0 (SM400 is always true so D4822 is constant)
D4820 = D4810 / D100
And from Rung 152:
D100 = 1000 (Constant)
And Rung 74 the main one :)
D4810 = U0C/G802
So I am guessing I should somehow reconfigure the program to generate desired numbers on Buffer memory U0C/G802 for the required points to be added to servo motion. But U0C/G802 is not repeated anywhere else in the program and I do not know how I can do it.I also need to mention that we are using Mitsubishi MR-J3-40B servo drives.
I hope this has provided enough information and thank you in advance for your help :site:
what CPU are you using?
What is the module order and part number? (rack layout)
Which version of GX developer are you using
CPU is:
Q10UDEHCPU
And I use GX Developer 8.78G
If you mean servo part number; it is unfortunately enclosed and literally not accessible.
And could you please tell me what is module order and where I can find it?
Tnx.
I have programmed servos from a handful of variety of manufacturers and series. Each time I used a PLC without motion functions. I have not worked...
731
I plan to use a profile sensor or something like that measure the distances between the gantry’s Z height and the Z height of the conveyor...
19
10,711
I’m fairly new to PLC programming. This is our first machine that uses an FX5 PLC rather than an FX3, and therefore GX Works3 instead of GX...
1,256
Hello everyone, So on Monday morning I'm expecting to have a box of random parts dumped in front of me. I'll create another thread with more...
1,981
I'm having trouble trying to get my servo to actually spin. I can't get it to spin even with the jog axis tool. Here is a screenshot showing what...
4,290
