SEW MOVIMOT control with ControlLogix 5000
I've not used that exact configuration, but I do a lot with SEW equipment and Logix PLC's via ethernet. SEW is quite good in that all their equipment is set up more or less the same way, with the same data structure and software, so I can't imagine it would be too different to the ones I've dealt with.
You'll need the SEW MotionStudio software (free download), and then it's just a matter of adding the device to your ethernet tree and extracting the data from your PD words. Generally the EIP assembly instance numbers and data structures are well documented in the manual for the device.
I'm actually quite close by to you, so if you need some on-site support drop me a PM and I'll get in touch.
Hi ASF,
Thank you for your reply. I'm trying to figure out the words and their meaning now. I'll let you know how it goes.
I haven't got the MOVIMOTS with me at the moment so I'm trying to set up the PLC software bit of the project.
Cheers.
Hi All I got this new project where the customer has around 200 SEW Movimot gear motors, where the actual drive is attached to the motor. All...
1,051
I am looking for SEW Movimot classroom training the USA, preferably in TX, even more preferably in/around Houston. Surely there is something...
3,224
Hi All, I have a project that lets me control a Movimot drive via Profibus DP. A quick search on google learned me that a lot of information...
2,786
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
234
Hi , I am trying to replace an old inverter with a new one and its giving me issues . Once the new one was installed , the S7-300 PLC started...
164
