Showing an array value in WinCC Flex doesn't work
userxyz
May 2002
any
2,768
Showing an array value in WinCC Flex doesn't work ??
Array index 1 has value 4:
Array setting in the DB:
Showing The value in wincc flex:
In Runtime I have zero ???
WinCC Flex configuration:
In WinCC Flex, array numbering always start from zero.
Thus, your variable ORDER_NUMBER.VARi[1] in Flex points to ORDER_NUMBER.VARi[2] in S7.
To align both arrays on Flex and S7, change the S7 array from ARRAY[1..500] to ARRAY[0..499].
Okay thanks
Weird, why is this different then a PLC ?
Okay thanks
First the Byte Swapping thing with the discrete alarms, now this...
tssss
Weird guys at SIemens,
I've red something funny a while ago... 2 Siemens dudes that were engineers. The one eated the other one. Canibalism. In germany. They're totally crazy :)
cjd1965 said:
Thats Siemens logic for you. :)
Jesper
DO you know why I can't connect many I/O fields to an array of strings ? See my other post
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
118
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
402
Hello. I am working in FTVSE v8. I have many trends set up some of them work others do not. The ones that don't work show the foot print of the...
247
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
111
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
259
