Siemens 315-2 dp Hardware reconfiguration
mdu
Apr 2012
swaziland
i have a Prosonic FMU95 module (from Endress and Hauser) new slave and i want to reconfigure the hardware (add a profibus master network) of the Siemens 315-2dp without making changes (orphaning the other slaves) to other slaves that are currently connected to the PLC and download this to the PLC.
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
751
Hi We were having a few power cuts and the CPU would not work. I had to reset the memory and he CPU would read from the memory card and start...
3,165
Hi, Can anyone explain the difference between rebooting a Siemens CPU 315-2 PN/DP, either by setting the switch into stop and back into run...
2,687
Got a call out to a customers site tomorrow. They have the above PLC and accompanying wiring diagrams from Nov 2013. Anyone any idea if you can...
1,431
Controller 315-2pn/dp installed on the bridge crane. Sometimes (1 time in a week or often) change its condition from RUN to Stop mode. I have...
3,593
