Siemens Analog Card problem
Test400
Feb 2008
Ottawa
Hi Everyone,
I'm using a 4-20ma pressure transducer, with a Siemens 2 channel 12 bit analog card (331-7KB02-OABO).
I set the card jumper to 2 wire reading,I wired the transducer to terminals 2 and 3 (CH 0) supplied power to the card at terminal 1(L+) and common to 20(M) and 10,11(Mana)
i tested the transducer by itself, with a ammeter it gave me the proper 4-20ma.
But once i hook it up to the card it pulls the current down.
has any one come across this? or could help me out?
regards
Test400
Check you have not got the jumper 180 drgrees out (I have done this!) Do you have an "SF" fault led lit? I had this fault myself when I tried to connect a 4 wire device but had the jumper on 2-wire. If the device is two wire (And not connected into any other plc/instrument it SHOULD work)
I have a Siemens connection diagram on my work pc (Am at home for the weekend) so I can dig it out on monday. You could try googling "Siemens analogue connections"
Hey guys! I have come across an unique issue. Hoping that I can find some solution here. I want to replace an existing S7-1214 DC/DC/DC plc with...
4,688
Dear, I came across an analog card from SIEMENS to be used for transferring analog signals. I couldn't understanding the cable length included...
1,077
Hello Experts, I need your help about this issue of mine about my Siemens Analog Input Card SM331 having SF LED lit. I know this is system fault...
4,492
Hello, new to the forum, been here over the years on and off, but now I am more involved at work so I run into more difficult problems.... Maybe...
3,982
I want to control a rectifier output current by using Siemens analog output card SM332 so pls help in configuration of analog output card.
1,682
