I have a question about the following IO card: 6DL1131-6BL00-OPH1. This is a 32 channel card that can be used as 1 wire or 2 wire. My first question is in relation to the power supply. just to confirm that the card itself needs 24VDC to operate and this is supplied across terminals 1p1 and 1p2?
can this card be used for the following valve box ( think top V50) where a separate 24VDC supply is taken to the valve box and then the closed signal on pin 4 for example is taken back to DI.0+, does this still count as 1 wire?
thanks.
thanks.
