Siemens DI card
Lc1
Jan 2014
Uk
59
I have a question regarding the DI module 6DL1131-6BL00-0pH1. This is a 32 channel module and it says that it can only handle 2 wire devices with either a potential distributor or an external power supply. My first question is what is the potential distributor is it a bulky module? Also there is a drawing on page 14 of the manual that shows sensor connection with an external power supply and says 2 wire but this has 3 wires L+,M and Di.n+. Has any one used this card before as the same drawing appears on the 6DL1131-6bh00-0ph1 as a 3 wire connection ? Is there a huge difference between these two cards in terms of operating principles?
Thank you
Hey guys! I have come across an unique issue. Hoping that I can find some solution here. I want to replace an existing S7-1214 DC/DC/DC plc with...
4,731
Dear, I came across an analog card from SIEMENS to be used for transferring analog signals. I couldn't understanding the cable length included...
1,083
Hi We had a faulty DO card giving SF error in our Siemens PLC setup model 326-2BF01-0AB0 and we replaced this 326-2BF41-0AB0 I/O card. We updated...
2,049
Hello, we have a 4 wire analyser transmitter (Mettler toledo M300 single channel measuring PH) two wires are for the 24VDC power supply and 2...
1,288
Hi, I have a question about the following IO card: 6DL1131-6BL00-OPH1. This is a 32 channel card that can be used as 1 wire or 2 wire. My first...
1,181
