Siemens Comfort Panel - Displaying PLC status
(8{)} ( .)
Apr 2004
Israel
625
Hello all Siemens people.
I've been tearing my hair out with something that should be trivial. Siemens tech support seems to have been separated at birth from Microsoft tech support, if you get my drift.
All I have to do is display the PLC connection status (Green = Good, Red = Bad) on the screen and generate an alarm when the status is bad.
I've been through the Siemens documents but they don't line up with TIA portal. I'm using a Siemens TP1200 comfort panel with an S7-1200 controller.
Is there anyone out there who's done this or who can send me an example?
Thanks,
Yosi
Use the system event 140000 for setting an internal tag to ON, and system event 140001 for setting the same tag OFF.
Use the tag to visualize the connection status.
Thanks Jesper.
That's what they keep telling me but I'm not a Siemens guru. Where do I find these events and how do I configure them?
Thanks again.
Yosi
Bratt/Jesper,
I never knew you could do that, thanks for the tip!
It is possible in WinCC flexible too but you have to tick an option to display the system messages. They are not shown default in flexible like they are in TIA.
Thank you Bratt. Such a simple explanation. Why couldn't Siemens have just pointed that out?
Yea, I bet they keep the answer on prominent display in a drawer in the basement in a room that has a "Beware of the Tiger" sign on the door...
Hello all, Thank you for your very helpful community. By way of introduction, I have written an interface that interrogates a customer's ERP...
2,400
Hi, Was reading about the latest comfort panels having Libre Office preinstalled. Can Libre Office be installed in older versions of comfort...
1,812
Hi all! I would like to be able to export some data from a Siemens Comfort panel. I want to end up with a nice PDF document, but I am...
3,259
Hi there, So i have the siemens comfort tp700 hmi. I want to print using printserver and laserjet, but is there any way that i can change the path...
1,578
Anyone know of a way to enable smartserver on a TP1500 comfort without having to have the original project file? I don't even get the remote tab...
1,833
