AlecTek Member A Join Date Sep 2010 Location Vancouver Posts 155 Jan 29, 2013 #1 The trend values can take up to 999, but is there a way I can sample every hour and thus I can have have a 999 hour trend view? Thanks!
JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,324 Jan 30, 2013 #2 Set update rate to once per hour. But that will give you one sample per hour. Not 999 hours with many samples per hour.
Zane_Terblanche Member Z Join Date Dec 2012 Location Newcastle Posts 63 Jan 30, 2013 #3 I think that you are correct in that he wants to view a 999hr trend despite only 1 sample per hour. High frequency may not be so important to him.
AlecTek Member OP A Join Date Sep 2010 Location Vancouver Posts 155 Jan 30, 2013 #4 Thanks for the helps. :site: In fact the the update rate on the trend view property does this trick, which I thought it was the update rate of the tag in HMI. I do need a higher frequency input.
JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,324 Jan 31, 2013 #5 It must be a very slowly changing process value. Room temperature ?
