Siemens Data Structure. Frustrating
bornwild
May 2010
Riyadh
429
Hello all,
I am a Rockwell guy and just started with siemens. The data sctructure frustrates me. Especially the swapped bytes. Can someone explain me with respect to Rockwell? In Rockwell, I can make a DINT type tag called MODE and pull it individual bits from it. For example, if there is 4 in my dint tag I will KNOW that Adress MODE.2 is having 1. How do you do in siemens? I have a value like 16#16000 in siemens . What would the individual bit bits be? I can check them inddiuvally. In Rockwell, I could check each bit. Suppose I make a tag a DINT tag in siemens. Can we address each bit like Rockwell? Please let me understands
Two other options would be to create an array of bools, or to create a structure/UDT with named bools.
The nice part about creating the bools as a struct is for situations where you are tracking modes/states/etc, you don't have to keep track of which number means which (oh wait, is "idle" mode.2 or mode.3?). It just becomes "Mode.Idle".
I will grant you that you can also just add it as a comment in the array (then you would be accessing Mode[2]), but most of the time I find creating the UDT more straightforward.
172
Dear Experts, Please, kindly guide me through how to read data from ABB PLC to S7-1200 Siemens PLC. I want to use Siemens S7-1200 PLC to read data...
456
Looking for options to write data to Siemens PLC. Looking for something closest to way we were doing it with AB PLC and excel sheet. Old way...
910
Hi, I've created this 'report summary' page (see pic). Basically, this screen is a summary of all the tags saved (by pressing a SAVE button)...
78
9,110
Anyone know how I can convert DTL to DATE type? This rung is trying to determine if the system is in calibration by subtracting the current date...
589
