Siemens S7/TIA v18: Logging of Data...
Just out of curiosity, I've never used the CPU itself to generate a csv file for a report before, only to log recipe parameters etc... same principle I guess.
Is there a way of accessing the csv file from a HMI, for instance a comfort panel that's enabled to use VBA scripting?
I'd like to know if that's possible too.
At the moment, I'll be saying to the operator "If you want to download the log files, you'll have to plug an Ethernet cable into the PLC and use a web browser", which they won't be too happy about.
You can also log data on the HMI itself. Not sure if it's a completely different log or if it can display the same one as it's not something I've looked into.
I know if the data is on the HMI it can be stored on a USB drive.
Yes normally I generate reports directly in WinCC that are then saved to a network location, for this very reason.
I see your HMI can't run scrips, so no go on my usual solution.
I don't have an application yet for a HMI reading a CSV from the PLC memory card, but it could end up being useful.
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
666
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi, The operator has reported that, from time-to-time, when he presses the "Generate Report" button...
463
General Question: The PLC and HMI that I've been working on (a laser measurement system) is soon to be transported to the site where it will be...
700
Hi, I'm not sure how to do this... Basically, I want to restrict the user input values for this tag to be in the range 20.001 to 25.0. I...
17
1,633
Can someone help me with this? I'm no good at SCL - virtually everything I've done so far has been ladder logic. The return value from the...
1,107
