Siemens HMI-Paneles and Datalogging
edda
Jun 2008
At the office
100
Hi everybody!
Normally I work with Beijers panels only but now a customer has a couple of Siemens panels (MP277 10" Touch and MP377 15" Touch).
With the Beijer panels we are logging some data, the data get´s saved in the builtin FTP-Server... From the FTP-server I upload the log files (*.csv) to another system and processes them there.
Is this possible in the Siemens Panels? I took a quick look in WinCC flex and from what I could see it was possible to save the log files on a network drive... But is there any FTP server support or anything else?
Best Regards
//Edmund
Hej Edmund.
First, you need to install the archives option on the panels in order to log data (on the newer comfort panels logging is included in the standard setup).
Then, if you install the smartservice option on the panel, then the panel can be reached via a webbrowser. And then it should also be possible to reach the file system on the panel for uploading of the logged data. I havent actually tried the last part myself, but that is how it should work.
You can try both even if you dont have any license for the above options yet. You will just get a nag-screen on the panels every now and then.
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
100
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
314
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,452
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
164
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
587
