Siemens HMI tp27 questions
Ozymaster
Jun 2015
Sheffield UK
Morning all.
iv inherited a machine with a Siemens tp27 touch screen HMI unit on it, and handily the operators have just smashed the screen, its still usable but we need a spare to replace.
internet searches suggest the unit is now outdated, (and i believe its replacement is now out dated) any one suggest a suitable replacement? and also what software would we need to get it up and running?
im not a programming expert but i have done some basics with Siemens s7 although anything more than basic lader and FBD starts to go over my head.
cheers
TP 27 6" or 10" only has 2 TTY and one MPI/PPI interface (to old for USB).
If you're looking to update to a current model, then that would probably be a Basic panel. Hypothetically, it should be possible to migrate the protool project into WInCC Flexible, and then to migrate the WInCC Flexible project into WInCC V13, the current software.
That is, IF, you have a copy of the HMI project. If you don't, then you might be able to do a binary backup of your current TP27, but then it could only be loaded into another TP27.
Thanks for that nonuke. I just noticed you also pointed out in your previous post that the software needed is Protool which I missed.
Just for Ozymaster's reference Protool projects can be imported into WinCC Flexible if you don't have Protool but have a copy of that on your system.
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
100
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
313
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,451
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
164
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
587
