Siemens MP370 Symbol Animation
cjd1965
Apr 2007
UK
1,659
Hi
I have inserted a symbol from the standard built in symbol library (looks like the Reichard library to me).
I wish to use different colours to represent different states (ON/OFF/FAULT)
I have selected Animations>Appearance and assigned a tag.
I have made this an 'integer' tag and created 3 states for a value of 0,1 and 2 with different colours for each.
The colour does not work in runtime. I realise i can work around using 3 objects and play around with visibility bits but wonder why i cannot use the Animations>Appearance bit which looks very much like the Color Animation I am used to in in GE Cimplicity HMI
Edit : I am using WinCC Flexible 2005
Cheers
Hi Charles I have definetley ticked the box. I will post a screen grab later, my project is at work. I tried to do that but my screen grab was over 300kb so unable to post. I need to resize it to make it fit
Cheers
Thanks for the tip Jesper.
Image of screen area attached below (GIF). Sorry it is a zip file but had problems with the upload picture dialog not loading
Hi cjd1965.
I dont normally use the library graphics. This seems to be one of the reasons why I dumped them back when I started with WinCC Flexible.
The only animation that can be attached to the .wmf graphics are visiblity and flashing. Forground and background colors are ignored.
I create my own graphics from the simple objects, lines, circles, etc. and I can then add the desired animations. It does take some effort.
Thanks Jesper. I assume I need to do a workaround where i have 3 different blocks with visibility set to 0 / 1 / 2.
Seems a pity for Siemens to include nice graphics that you cannot animate.
/Rant On
I think that WinCC Flexible is not so flexible after all.
Cannot Export / Import a complete tag list to Excel
Cannot Export / Import a complete alarm list to Excel
Cannot animate included graphics library
All of which are functions i would expect from a modern package.
In the GE Fanuc world I am used to I can and do use all of the above to greatly minimise development time
/ Rant Off
Cheers
Hi guys, While trying to upgrade a Siemens MP370, it hung somewhere in the process and gets about halfway through the creation of its disk...
2,780
Need to put in a new touchscreen digitizer. Does anyone know the procedure or how difficult this might be? Have never taken one apart, so I don't...
1,408
Hi all, I have a problem with a Siemens MP370 touch panel. The original panel had a fault with the touch sensor, so a new unit was purchased to...
7,324
Hey i want to make a trend on a Siemens MP370 15 TOUCH 6AV6545-0DB10-0AX0 And need a storage card MP370 have USB-PC-card and CF-card, i wonder...
5,113
Hi all, I have a Siemens MP 370 15" touch HMI connected to an S7300 over MPI.. I have the source code application in WinCC 2005. I am trying to...
1,942
