Siemens PLC and HMI Time Synchronization
timaldred
Sep 2005
Aberdeen
I have a 315 series Siemens CPU and two Siemens touch panels running Wincc flexible standard that I need to synchronise the time on.
......Just something else you don`t get on the course........
If any one has a simple example of how to do this, it would be greatly appreciated.
Hi Timaldred,
would you pleas explain by what do you mean by synchronize them,Do you mean cycle time or what ?
Regards Gasser
What type of Network?
Are the PLC and HMI's connected via PROFIBUS or Ethernet?
There is an option in the screen to synchronize the times if you are using profibus. That option is not available over Ethernet.
If you are using ethernet, I would write a script that sets the HMI time based on the PLC time, and have it run every 6-12 hours. You can do this with tags.
The hmis are both connected via profibus. I`ve got it sorted now and both are synchronised with my plc. For once I managed to hit the right search criteria on the tech support FAQ page, which is a first for me o_O
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
112
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
602
I'm a bit lost. I don't understand why my HMI (Simatic 1200) is not recognising any PLC tags. From the ethernet comms page , all seems OK. Yet...
2,232
Sorry for the basic question: At the moment, the PLC [S7-1200] is connected to a laptop (contains TIA Portal) via the ethernet port. When I add...
1,548
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,649
