Siemens S7 CPU Locked
Password are save in MMC cards, what you need to do is, unplug the MMC card , use card reader to read out the password . You need a software to read from MMC cards. The software will generate out the password code. Plug back MMC cards and use this password to unlock it.
I remember my friend also encountered such a problem, he did everything through the firmware of the apprarat. I shared a full reward through the official software. And then everything seemed to work! I don't know if I can find it now
The bigger question has to be why is it locked?
1)Is it one company trying to protect their IP?
2)Is it a disgruntled employee trying to avenge severance?
3)Is it to stop other none authorised employees "messing with it"
if it's (2) then restore a backup
if it's (3) speak to the system owner
if it's (1)...... then sort out IP and commercials or stop cutting cost, or face up and wipe the PLC and start again (File NEW).
Hey when I turn on my Siemens PLC CPU 216-2 after runing 10 minute it's stop and showing SF indication after I turn off and some time later turn...
124
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
113
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
751
Has anyone come across this kind of problem: I have 1215FC cpu with profinet and profibus devices. Because of one device, I would have to...
977
First of all, it's a pleasure to join this community, I already have a few years of exp in this sector but never registered on a plc forum, so...
794
