siemens s7/step software
RY_Guthrie
Nov 2011
Las vegas, NV
263
I am needing to connect to a siemens s7-300 plc, I have step 7 basic but as far as I can find online I need the professional version to go online and edit the code. Can anyone verify that for me? Also is the software backward compatible, example, if I have version 7 can i go online with a plc programmed with version 6? I tried getting online help but it being the weekend that isnt available. thanks!
RY
Look at you working on a Saturday :)
Can you be more specific on your version of software?
But yes. You need professional for s7300
It is possible to download a trial version of STEP 7 Professional (TIA Portal) or STEP 7 V5.6 TRIAL (often referred to as "Classic"). Which one you download will depend what variant of software was used in your original offline project.
If you have a .zapXX file (where XX is the version number of TIA Portal), then you have a TIA Portal backup file.
If you have a .zip file with many folders and a .S7p file in it, then it is the Classic backup file.
As mentioned by sigmadelta, there are two packages called Step 7, the newer TIA Portal (v11-v15) and the older Simatic Manager (v5.6 and below).
V15 can technically go online with a PLC downloaded from V14, but you can't do much.
V5.6 has full online capability with v5.5, on down to something like v5.2, which is a LONG time ago.
Please excuse the basic question, but I've never worked on Step 7 before (until now, only dealt with Mitsubishi Q-series PLCs)... What is the...
3,345
I am using a Siemens s7-300 PLC and using Step 7 software to reach it. However last week I could communicate with the PLC and change online and...
8,768
Does anyone know if there's any software out there that will allow me to "simulate" the Step 7 software I write on my PC without having to...
20
59,842
I was speaking to a contractor today who reckons Siemens are working on some new software for programming 300 series PLC's. I wondered if he was...
99
78,848
Can i find any where, the Siemens STEP 5 DEMO programming software for learning purpose?
19,275
