Siemens Step 7 college programs PDF Help
IrishRover
May 2012
London
Hi Guys, I am currently finishing a PLC course on siemens Step 7.We were given a trial version of Step7 with a 365 day license, However I could not get it loaded on my Laptop,Anyway to make a long story short , We did the labs in class and all ok, Then at the end of the class he asked us to print out the ladder diagrams (screen shots) at home and present on paper.Now i assumed i would be able to load the program onto my wifes laptop and print off, Not workingWould there be any kind person who could convert to pdf the ladder diagrams or even a couple of screen shots. The files are archived compressed, They are all small ladder diagrams , about 7 in total.I have tried other open source programs i.e. PLC edit and CoDeSys but none open the siemens archive file. If any one could help i would be most gratefulThanksIrish Rover London
Try to reinstall Step 7...Make sure License manager is properly installed...Check compatibility with your OS...If all goes well Install Cutepdf which is free...Open block that you want to print Go in "file" option, select "print" then select cutepdf writer...
Thanks to all for reading, also to comments to reinstall, unfortually i must have a bad copy as it will not run on a number of pc's for me.
Annway the time has come to get it printed for college asap, so thank you Mark , i will take you up on the offer of converting to PDF for me.
I can only upload 5 fiels , i will attached the next few on another post
Attached all archieve files
Thanks again
Aid
Irish Rover
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
254
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
690
Hello, We monitor the temperature of a pipe via a 4-20mA temperature transducer. This goes into DB135(Read Analog Inputs). The issue I have is the...
631
Please excuse the basic question, but I've never worked on Step 7 before (until now, only dealt with Mitsubishi Q-series PLCs)... What is the...
3,349
