Siemens Step 7 Convert
RheinhardtP
Oct 2004
Perth
562
Hi All,
I'm currently busy on a project where i must take a number of char type objects and convert them to a decimal number for comparison reasons.
i tried the standarD Step 7 STRNG to INT conversion with no good values.
I understand the string concept like following.
Variable type STRING[5]
STRING[ABCDE]
byte 0 Max No of Char
byte 1 Actual amount in String
byte 2 A
byte 3 B
byte 4 C
byte 5 D
byte 6 E
Is there any tip or trick to getting this conversion going
I would really appreciate any help.
If there are any requests i'll post my code on this topic.
Kind Regards
Rheinhardt
Hi Rheinhardt
What values do you have in Bytes 0 and 1? You may have to load these with something between 1 and 6 (or in your case 1 and 5) to ensure the STRING variable is correctly recognised. For example if these bytes contain 0 then no conversion will take place.
Are you sure the STRING value can be represented as an INTEGER? Is it within the bounds for an INTEGER data type?
Regards
Ken
I haven't used FC38 before, but here's the code I ran and checked in the simulator. In the first example I used a string variable in temp local data and fill the string in using the program, the second example uses a string defined in a DB. Note that the DB has to be in the symbol table.
Code:
	 LAR1 P##sValue				 //string data type in temp area
	 L	 5
	 T	 B [AR1,P#0.0]
	 L	 4
	 T	 B [AR1,P#1.0]
	 L	 '1'
	 T	 B [AR1,P#2.0]
	 L	 '2'
	 T	 B [AR1,P#3.0]
	 L	 '3'
	 T	 B [AR1,P#4.0]
	 L	 '4'
	 T	 B [AR1,P#5.0]
	 CALL FC	38
	 S	 :=#sValue
	 RET_VAL:=#iValue
	 CALL FC	38					//string declared in a DB
	 S	 :="dbStrings".String1
	 RET_VAL:=#iValue
Structure
Dear Ken,Simon
Thanks for your replies.
Ken,
I load the values into my 1st and second byte . Since my string is defined in a data block as value == string[5] it loads the first byte automatically. I have loaded the value 5 into my second byte, but even with a value of '00000' i get INT 20000.
My STRING VALUE is defined as follow.
VALUE String[5]
byte 1 2 3 4 5 6 7
16#05 16#05 '1' '9' '4' '6' '3'
My return out of FC38 os then 20000. strange I will try your tips when i get to the office and post my code.
Simon you never said your result in the similator was it sucesfull??
Thanks again
Rheinhardt
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
267
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
569
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
721
Hello, We monitor the temperature of a pipe via a 4-20mA temperature transducer. This goes into DB135(Read Analog Inputs). The issue I have is the...
641
Please excuse the basic question, but I've never worked on Step 7 before (until now, only dealt with Mitsubishi Q-series PLCs)... What is the...
16
3,388
