Siemens Terminal for F-DI 8×24VDC HF
iadapt
May 2012
Indiana
177
Hello,
I am troubleshooting a fault on a Terminal assignment for F-DI 8×24VDC HF. Terminal 15 says its a; VSn: Internal sensor supply, channel n.
What does that mean?
I have a circuit going from 15 to 6 with an estop in the circuit.
Hi Guys, Hoping we still have some Siemens Old hardware Gurus on here. We are trying to support one of our long time customers. Who have obtained...
967
What is the difference between Siemens terminal block 6ES7193-6BP40-0BA1 and 6ES7193-6BP40-0DA1? Can they be used interchanged for an analog...
1,245
Hi Basically I have a date/time field set to TIME only and using an internal DATE_TIME tag On power up the date/time field shows ####### which I...
2,144
Hi guys, Any of you guys know if using ET200S, do I still need to put terminal block (Wago/Pheonix Contact)? Can I wire the field signal cable...
2,768
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
67
