Siemens tia storing a string
stu
Aug 2005
England
783
Hi
I have a vision camera that I’m getting the string data P908765 from the vision on an advance trigger .which im using a S -move. Then I put that into a <> to compare 3 codes.
But I’ve noticed that when the advanced trigger is not active I get drop the value.
I’m thinking I need a storage of the string so very time the code updates it stores it in the compare function and on the display,
How would you store a string, would you move the vision string to another string and then S-move that to the display
Stu
Yes, make a string tag in a relevant DB (or as a static of your FB, whichever), and move it in whenever a new value is available. Then have the compares and the display point to the new tag.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
446
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
210
Does anyone know why my one string is displaying this way? It is causing issues with my HMI displaying it.
266
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
666
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi, The operator has reported that, from time-to-time, when he presses the "Generate Report" button...
463
