Can I download my Protool project from the PG to the touch panels through Ethernet module (CP343-1) then CPU module and MPI. The transfer route is shown with blue arrows.
I'm using Protool.
See the attached scheme.
I think that we should continue in the other thread.
If not we will see the same questions asked and answered several times. Confusing.
A tip: If you have accidently started two threads at the same time, then you can select the "edit post" button and then delete the extra thread.
But you only have 1 hour before it is too late.
