Simatic manager defaults to TCP/IP - >Intel etc
Wilso
Nov 2012
Newcastle
144
I want to connect the programming PC to the Safety PLC using a USB to MPI/DP cable. I know the cable works as I've used it before. All the lights come on. I set the interface to PC Adaptor(Auto). I also tried MPI and Profibus. But when asked to select the download device, I can't see it on the accessable nodes. Significantly (and I don't know if this is an indication of the problem), when I exit from the hardware configuration, it automatically defaults back to the TCP/IP interface.
do you have MPI enabled on your PLC? might have configured it for Profibus?
also, do you have any HMI connected to the same port? sometimes this gives trouble..
You'll have to tell me. Programming device isn't shown but it connects to the Industrial Ethernet only.
In NetPro, What network is the PG connected to?
The Netpro configuration will overwrite the PG settings.
If the PG is in the Netpro configuration for the project, it's configuration in Netpro will override your PG settings.
I tried it with another PC, and still the same. I didn't want to try to connect with another PLC.
Continued to do some research, and started by checking the accessible nodes, where I was able to see the safety PLC. Shown here as SIMATIC 300.
Properties as shown here
I don't know how it does this, because it currently doesn't have an ethernet connection. Something to do with the routing?
So I turned the PLC off. Installed the ethernet card, and powered it up. The PLC goes into stop mode.
In the hardware configuration I inserted the new card into slot 7 of the main rack (which matches the physical configuration)and set up MAC address, IP address, gateway etc.
Did save and compile ok, then clicked download. Was offered a choice of accessible nodes to download to, and chose the one based on the properties I initially found.
It did a few things and then gave me this message about online and offline not matching. I know that the information shown here is garbage. Nowhere in any configuration, or physically, does the online module shown exist.
Clicked ok, and it proceeds as if it's going to download, before getting an error message.
The details of which are.
This is deeper than I ever expected to delve into a Siemens (or any) PLC.
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
355
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
290
Hello all. I went to a customers location, uploaded from the S7-300 (CPU312) and performed a save, performed some work then came back to the shop...
646
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
778
Hi, I have recently gone full in on TIA after holding on to Simatic Manager. One thing which I find more difficult is the filter function for...
1,749
