simatic s5 BF
cabooo
Nov 2018
baghdad
dear all
we have a production line working with s5 plc (155U) and a 948 cpu
there is an interface module 308-3ub11 to connect the other s5 95u plc and et200 units via a profibus cable
we have two loops and each loop terminated at the last point ,
from MMI we select what we need units to start the line and there is only one unit made a bf to the other units if i select it and start the line , in simple form ,i can choose what i need to start the line so there is only one unit when i made selection and tried to start the line its made a bf to the other units in et200 (i can see the BF in et200 flashing two or 3 times and then gone )
and when i tried to start the line without this unit all line working properly.
also if i tried to start this unit only , its make bf to the other unit also
this unit have a S95u plc
thanks
It can be an electric fault pulling down you're powersupply when you start this unit. Maybe a selonoid or some other electric equipment in that unit?
thank you for response
when start this unit locally through jog mode or push button its working properly , but the problem appear in the other units (s95u and et200) a bf flashing 2 or 3 times and then bf gone , if i started it from HMI
i am afraid that there is fault signal going from this unit to the interface module 308
and cause this situation.
i appreciate your reply.
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
97
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
175
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
312
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
324
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
164
