simatic S5 IP240 not working
rgua
Mar 2003
144
[FONT=Arial, sans-serif]I have a problem in a Simatic S5-115 cpu 944 with single PG port
The machine worked
plc has two IP240 cards. In the first card, the second channel is not working
In the second card, the first channel does not work.
In the bad channel DB /DW13 appears hex02010 = channel not configurated
In some circumstances, 'appears hex0101 = ?? no documentation ???
In the FB169 and FB170 PAFE turn on bit 1 = parameter and data errors[/FONT]
[/FONT]
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
99
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
177
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
313
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
327
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
166
