Simatic S5 -Seven Segment Display
sam_1977
Nov 2008
Egypt
Dear Friends,
simply iam taking my very early steps into the SIEMNS S5 and iam surprised by the first task i need to figure out
i have in my S5 Program (specifically, in DB)a value that is sent from PLC to "process visualizing software"
anyway, my target to display this value in DW of DB on 7 segment display ,could anyone please help me to configure how is that?
thank you in advance,
sam
Depends on the type of display?
Can be as simple as an output byte in hex or binary code thru to RS232, 20mA, RS485 etc.
Have a look at london electronics.
I have ever used 4-digits 7-segmet directly to digital output for integer value (2 bytes) . Value from DB or F is converted into BCD then I move it directly to digital output just using Load/L and Transfer/T function.
I connect each 4 bit of D/O to each digit number of 7-segment. Remeber to make 0-9 number in 7-seg you need 4 bits
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
172
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
311
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
322
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
158
