simatic s5
santykadam
May 2006
Cairo
i havees simatic s5 135 with analogue output card 6es5470-4uc12.there is only one current output is connected to this card ,however this ouput is not working i mean there is a problem and dont have any spare but i have another output card with voltage output installed on the same system and one output is empty
to swap the current output to voltage one what are modification in the programme have to be done
awaiting for reply
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
97
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
176
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
312
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
324
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
164
