Simatic S7-200 pc/ppi cable usb<->freeport
I don't know for sure. But if you can select your USB-PPI cable as a COM port in a simple (or less simple) terminal program such as Hyper terminal, then I guess it should be possible. I think you better try this first. If it works, I think you can use this cable in the same way as a RS232-PPI cable.
I think this should work, because I used to hav an internal modem and I could also control it as if it was a COM port. I wont compare to my USB-RS232 converter, because there the sole purpose is to use it as a COM port.
Good luck and please don't forget to inform us all here about the results. There are others who might use this info.
Kind regards,
I have just received the Siemens Knowledge Base Edition 12/03 and guess what I've read in it:
The smart PPI cable has two modes of operation, … the PPI mode and the Freeport mode.
The Smart USB Cable has one mode of operation, … the PPI mode.
There it is: it's not possible to use freeport mode with the USB cable. If you want to read the complete article, search the Siemens website for entry 15159037.
Sorry if I gave you any false hope.
Kind regards,
hello, if i want to extend(make the extended RS-232 by my self) the simatic s7-200 RS-232/PPI multi master cable on PC(RS-232) side, is right if...
1,581
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
97
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
507
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
766
I have new Siemens PLC / Simatic S7-1200 Need software download to use the PLC Please advise Thanks Wally
2,256
