simatic s7 PC ADAPTER USB
ajay34
May 2010
klang
249
hello all ...
i m facing problem with my laptop cant get online with s7 plc.
i had install simatic manager . when i plug to usb adapter but not working
attch is pic of thing happen..i still trying to figure what is wrong ,,
my pc is sony vaio only have usb port and window 7 pro 64bit.
it new laptop pc
attach are error i m getting ..
With tia portal it was either my firewall or the ip settings.
Try disabling firewall and wifi and then check the ip settings of your pc and PLC.
Hello there, I also bought PC Adapter USB A2 recently. I am using Windows XP SP3. I need to connect Simatic Manager with the same. Now the...
5,712
Hi there! I use a Simatic PC Adapter 6ES7 972-0CB20-0XA0 with TIA Portal V11 SP2 but cannot connect to an S7-314C 2 DP. It worked a week ago...
6,637
There is no “USB” item in the Set PG/PC Interface – Local Connection – Connection to, only serial port RS-232 (COM3) connection is there. I...
16,872
Hello, I know that I can program Simatic panels indirectly via the S7 PLC. We get 24V and 5V from the PLC's MPI port and distribute it to the...
3,728
greetz, i have a siemens simatic s7 pc adapter usb (serial 6es7 972-0cb20-0xa0) and plan on connecting it to the siemens PLCs in a goss web press...
6,586
