Simatic PC ADapter USB error
pacak
Sep 2006
Arad
65
Hi there!
I use a Simatic PC Adapter 6ES7 972-0CB20-0XA0 with TIA Portal V11 SP2 but cannot connect to an S7-314C 2 DP.
It worked a week ago. Now I get this error message:
"A connection between your PC/programming device and the PLC cannot be established."
140:17090
All the LEDs are ON (MPI, Power, USB).
In the Windows Device Manager it sais that the device is working properly. I have uninstalled the driver from there and after plugging in the USB, the usuall things happened: New hardware found, it is working properly etc. (Win XP Pro SP2).
I have tried the adapter with another S7 300 CPU. Same thing happens with same error message.
I have tried to install the PC Adapter Driver V2.0, but the installer sais that I have V8.2.
I have tried to connect also without a project, just using "Update accessible devices". Same error message.
If I set the Adapter properties to "Automatic protocol detection", I get the following message:
"The bus parameters could not be calculated automatically (online). There are no stations on the bus sending bus parameter frames. Set the MPI/Profibus parameters manually."
I also tried different baud rates without any success.
Any suggestions?
BR
Attila
Are you connecting to X1 with the adapter set to MPI, station 0, baudrate 187.5k ?
Or are you connecting to X2 ? If so, is the CPU already configured and the port enabled for Profibus ? You cannot do the initial download via X2, only via X1.
Did you try with another PLC ?
Did you try with another PC, but same adapter and PLC ?
Hi Jesper!
Thanks for the idea!
I have checked the adapter with abother PLC before, but not with another PC.
I just did it using Step 7 V5.4 and the adapter works with the other PC.
That means that I have a problem with my TIA Portal. The thing is that I have reinstalled the TIA Portal yesterday, in order to solve this problem.
So what should I do now?
Do you know how could I reinstall only that PC Adapter driver V8.2?
BR
Attila
hello all ... i m facing problem with my laptop cant get online with s7 plc. i had install simatic manager . when i plug to usb adapter but not...
31
8,647
Hello there, I also bought PC Adapter USB A2 recently. I am using Windows XP SP3. I need to connect Simatic Manager with the same. Now the...
5,712
There is no “USB” item in the Set PG/PC Interface – Local Connection – Connection to, only serial port RS-232 (COM3) connection is there. I...
16,873
Hello, I know that I can program Simatic panels indirectly via the S7 PLC. We get 24V and 5V from the PLC's MPI port and distribute it to the...
3,728
greetz, i have a siemens simatic s7 pc adapter usb (serial 6es7 972-0cb20-0xa0) and plan on connecting it to the siemens PLCs in a goss web press...
6,588
