Simatic S7 - RS422
Hi Jesper..
So
I tried configure simatic via the manual which you sended.
Cp341 are Ok.. No faults.. RX led flashing (tx no ) but when i create the DB and FB (db10,fb7(recieve data),db8,fb8(send data) - I use the libraries ptp->cp341)
I have problem with read data because nothing data showed...( Status of the Recieve is 0 )
.. please can you help me? where i have problem
Jesper..
Solved...
It was to easy, when i configured the same network ( laser or cp341 - bits/stop bits/ parity ) laser automaticaly send data do Cp341 because RxD led diode on the card flashed. I was sure it was OK..
but i didn´t know how can i read data from the CP341 card via DB block..
But ,,,, old and good push button F1 for Help had many answers..
Simatic have everything all ready in the library and exact procedure to set the comm
Once and last problem was correct read data from DB..
DBX.DBB 0
.DBX.DBB 15
I dont believe it
It was need a several easy steps to connect and consumed data..
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
309
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
321
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
157
