Simatic S7 SFC20(BLKMOV) Question
arocon
Oct 2006
Dubai
171
In one network SFC20(BLkMOV) is used to transfer 8 byte data from P#DB500.DBX8.0(SRC BLK) to P#DB20.DBX4.0(DST BLK).
I would like to change P#DB500.DBX8.0 to P#DB1000.DBX8.0. But it does not accept. Though both are same data type.
Could anyone please as soon as possible tell me what is the problem ?
Thank you
There are 2 methodes
1 Use any parameters
Code:
      CALL  "BLKMOV"
       SRCBLK :=P#DB500.DBX8.0 BYTE 8
       RET_VAL:=MW20
       DSTBLK :=P#DB1000.DBX8.0 BYTE 8
2 use symbolik adressing and siemens knows the any parameter
the byte's to move must be in a structure
Code:
    CALL  "BLKMOV"
       SRCBLK :="datablock500".ByteStruct
       RET_VAL:=MW20
       DSTBLK :="datablock1000".ByteStruct
You don't say what CPU you are using. DB1000 may be outside the addressable range of the CPU but probably not as you are already using DB500. The other thing to check is that DB1000 is at least 16 bytes long or there will not be room for the data.
Nick
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
169
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
305
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
319
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
156
