Simatic TP177B
Frenzie
Nov 2010
Beverly Hilland
I run a program with the WinCC flexible simulator.
Program is for TP177B. I get an alarm for "to many power tags".
Does this refer to the runtime simulator, or will the same problem occur when using the actual display?
How many powertags can the simulator handle, and how many can the TP177B handle?
It only pertains to the running of the simulated program on your PC.
The simulator runs with the PC RT engine that expects a license for the number of used power tags.
It does not matter for just simulating the panel for a short time.
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
97
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
176
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
312
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
324
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
164
